A big hello,
can somebody help me please?
I want to to use an arry to create 3 buffers with different distances. Mainly the code should produce 3 buffer files in one step. The code below runs after I use Arcgis Add-in but I have no imagination how to build in the arry and let save this 3 buffer files.
Can somebody point me please in right direction as I have no idea where to start? My system is ArcGis10.2, VB.net, Visual Studio2012
Thanks a lot in advance!!!
This is the code I want to modify:
Imports ESRI.ArcGIS.Geoprocessor
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.AnalysisTools
Public Class BufferButton1
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Public Sub New()
End Sub
Protected Overrides Sub OnClick()
Dim m_application = My.ArcMap.Application
Dim mxDocument As IMxDocument = m_application.Document
Dim map As IMap = mxDocument.FocusMap
Dim strInputFC As String
Dim strOutputFC As String
Dim intOutputBufferSize As Integer
Dim gp As ESRI.ArcGIS.Geoprocessor.Geoprocessor = New ESRI.ArcGIS.Geoprocessor.Geoprocessor()
gp.OverwriteOutput = 1
strInputFC = map.Layer(0).Name
strOutputFC = "E:\" ' in this path I would like to save the 3 buffer files
intOutputBufferSize = 1000 ' here I would like to handle three buffer sizes eg 1000, 2000 and 3000
Dim bufferTool As ESRI.ArcGIS.AnalysisTools.Buffer = New ESRI.ArcGIS.AnalysisTools.Buffer()
bufferTool.in_features = strInputFC
bufferTool.out_feature_class = strOutputFC
bufferTool.buffer_distance_or_field = intOutputBufferSize
gp.Execute(bufferTool, Nothing)
My.ArcMap.Application.CurrentTool = Nothing
End Sub
Protected Overrides Sub OnUpdate()
Enabled = My.ArcMap.Application IsNot Nothing
End Sub
End Class
Public Sub New()
End Sub
End Sub
End Sub
End Class
