Map projections are cool but they might be a bit scary. It’s difficult to understand how can you put a very complex round-shaped*surface of the Earth on a flat plane. After reading this post everything should be clear!
Portraying the features of a spherical surface on a flat plane
Map projection is portraying the features of a spherical surface on a flat plane. This cool image from the Rice Space Institute*explains everything.
Amazing Map Projection Explanation*From 1921
This illustration from the book “Elements of map projection with applications to map and chart construction” written in 1921 by Charles H. Deetz (born in 1864) and Oscar S. Adams, (born in 1874) is one of the best illustrations of the concept of map projections ever.
All map projections compared
This amazing website is comparing parameters of key map projects. There are really a lot of them.
Map projection can keep one parameter angle, area or distance undistorted
Mercator projection is conformal so it preserve angles making it perfect for sailing navigation.
Gall-Peters projection preserves areas. Now you can see that Africa is the largest continent.
This equirectangular projection preserves distances.
source: Map-projections.net
Mercator projection lies
When comparing conformal Mercator projection (black lines) and equal area Gall-Peters projection (green shapes) you can notice that the world as we know it from Google Maps is a lie. Africa is second largest continent after Asia. Australia is the size of Europe. Scandinavia is a tiny piece of land. And Greenland is not as big as South America. You want to learn more about the real sizes of countries around the world there is an*awesome tool*to discover it.
source:*flatearthdisclosure
Map projections are not boring
Map projections are all about math. This mean that you can do with them whatever you want to as long as each point on the map is mathematically defined. Check out these cool examples of crazy map projections:
What these map projections say about you
[td_smart_list_end]
The post Top 7 maps that ultimately explain map projections appeared first on Geoawesomeness.
[td_smart_list_end]
