Python and Webmaps: folium
We have seen some easy ways to create webmaps without learning JavaScript or loosing sort of control of our data in terms of using a platform like cartoDB, mapbox or AGOL (ArcGis OnLine). There are R and QGIS connectors which translates your current data and project to a leaflet or openlayers based webmap. Today I worked with folium which creates a webmap directly from Python. Follow me! Installation
God- I am atheist, so take this not too serious- I love “pip“: pip install folium pip install pandas And that’s it. Just type this in your console/cmd and pip will install the module as well as dependencies for your python installation. Maybe use a super user for installing. But still very easy! A Small Example
When it comes to webmaps you want to show some data and not only a basemap like google maps ore HERE… I would like to have a look at the median age of the population of the US states. Therefore I downloaded the US state data from the 2010 US census and converted it to a simplified, EPSG:4326 geojson and also altered/removed some columns (download it here) As known by leaflet and openlayers we will start with a basemap to put our data on and save this minimal map to a html file: import folium mapOBJ = folium.Map(location=[39.5, -98.35], zoom_start=4, tiles='Stamen Terrain') #which is the center of the us with zoomlevel 4 mapOBJ.create_map(path='map.html') Currently it seems like folium only supports the following basemaps:
  • OpenStreetMap
  • Stamen Terrain
  • Stamen Toner
  • Mapbox Bright
  • some mapquest
  • CartoDB Dark Matter
  • some more…
So let’s check this basic map:
The framework behind it is leaflet so you can easily enhance it with some leaflet/JS superpowers. Now let us add the geojson which is a simple one-liner: import folium mapOBJ = folium.Map(location=[39.5, -98.35], zoom_start=4, tiles='Stamen Terrain') #which is the center of the us with zoomlevel 4 mapOBJ.geo_json(geo_path='pop_us_simple.geojson') mapOBJ.create_map(path='map.html') At the moment the shapes of the geojson is plotted on the webmap. Now let’s combine this with some data. This get’s a bit ugly as we are coming from the geojson side which is a nested json and we don’t use plain jsons. The idea in folium is: join the shapes with additional information: import folium, json import pandas as pd #we will use this to store the properties-data in a "pandas" data frame mapOBJ = folium.Map(location=[39.5, -98.35], zoom_start=4, tiles='Stamen Terrain') #which is the center of the us with zoomlevel 4 and a custom attribution with open("pop_us_simple.geojson") as file: #first read the file and store it in an object data = json.load(file) data2 = pd.read_json(json.dumps(data["features"]), typ='frame') #now convert it to a pandas data frame data2 = data2.ix[:,1] # we select only "properties" as we don't care about geometry and stuff. data2 = pd.concat([pd.DataFrame.from_dict(item, orient='index').T for item in data2]) #each item in data2 is a dict. data2 has only one column with a dict. so we "slice" the dict into several columns. mapOBJ.geo_json(geo_path='pop_us_simple.geojson', data=data2, columns=['STUSPS10', 'median_age'],key_on='feature.properties.STUSPS10',fill_color='YlGn', fill_opacity=0.7, line_opacity=0.2) #this will add the geo from the geojson and connect it with the data in the object data2. "key_on" and first entry in "columns" must match. fill_color is from colorbrewer. mapOBJ.create_map(path='map_median_age.html') This is now a nice map:
We can also add some points to this. So let us add some markers for cities (file is here) and create a popup filled with data: import folium, json import pandas as pd #we will use this to store the properties-data in a "pandas" data frame mapOBJ = folium.Map(location=[39.5, -98.35], zoom_start=4, tiles='Stamen Terrain') #which is the center of the us with zoomlevel 4 and a custom attribution with open("pop_us_simple.geojson") as file: #first read the file and store it in an object data = json.load(file) data2 = pd.read_json(json.dumps(data["features"]), typ='frame') #now convert it to a pandas data frame data2 = data2.ix[:,1] # we select only "properties" as we don't care about geometry and stuff. data2 = pd.concat([pd.DataFrame.from_dict(item, orient='index').T for item in data2]) #each item in data2 is a dict. data2 has only one column with a dict. so we "slice" the dict into several columns. mapOBJ.geo_json(geo_path='pop_us_simple.geojson', data=data2, columns=['STUSPS10', 'median_age'],key_on='feature.properties.STUSPS10',fill_color='YlGn', fill_opacity=0.7, line_opacity=0.2) #this will add the geo from the geojson and connect it with the data in the object data2. "key_on" and first entry in "columns" must match. fill_color is from colorbrewer. with open("places.geojson") as file: cities = json.load(file) for city in cities["features"]: mapOBJ.circle_marker(location = [city["geometry"]["coordinates"][1],city["geometry"]["coordinates"][0]], radius=200,popup="Name: " + city["properties"]["name"]+ " (Population: "+ str(city["properties"]["pop_max"]) + ")") mapOBJ.create_map(path='map_geojson.html') This will create a map with geojson states and single markers with popups.
Summary
Folium is an easy module to create webmaps directly from within Python. I like it’s simplicity for easy tasks like points and markers. Yet it is not very well documented and simple popups over geojson polygons were not working. The development of folium is quite young and I expect some progress in the next weeks so you get support for all elements of leaflet in folium.The post Python and Webmaps: folium appeared first on Digital Geography.
