Volunteers collect macroinvertebrates from streams in Puerto Rico.By Rachael Graham
On April 9, 2016 more than 1,200 volunteers participated in Puerto Rico Water Quality Monitoring Day to measure…..you got it – water quality!
Over 150 sites throughout the island were sampled by volunteers from 30 municipalities as part of a worldwide effort to gather data using citizen science efforts. The data they collect will be uploaded and become part of a global data set for the World Water Monitoring Challenge.
This was the eighth year of the program coordinated by the San Juan Bay Estuary Program (SJBEP). Prior governmental and NGO sponsors for this event included EPA Region 2 Caribbean Environmental Protection Division (CEPD), Puerto Rico Environmental Quality Board (PREQB), the Jobos Bay National Estuarine Research Reserve and the Puerto Rico Water and Environment Association (PRWEA). For 2016, EPA Region 2’s Division of Environmental Science & Assessment partnered with SJBEP and CEPD and sent two biologists to provide technical assistance and training on additional water quality parameters for citizen science.
For the Water Monitoring Challenge, group leaders were trained to use a standardized water quality kit to measure dissolved oxygen, pH, temperature and turbidity in weeks prior to the event and then pass this training on to their individual team participants. In 2016, EPA added two other important water quality parameters as a pilot – E.coli and benthic macroinvertebrates.
Approximately 20 volunteers collected samples from 21 locations throughout the San Juan Bay Estuary watershed for analysis for Escherichia coli (E. coli), a common fecal bacteria found in sewage and animal waste. Each participant set up a test to measure E.coli that does not require any equipment and can be incubated at room temperature, called a Compartment Bag Test (CBT), which has everything required to measure E.coli in one small kit. EPA and SJBEP personnel took split samples of the volunteer samples and measured a more rigorous test for E. coli to compare results. The objective was to test the CBT method to see if it can differentiate between low, moderate and high levels of E.coli. Since rapid tests, like the CBT, are simple to conduct and require no laboratory equipment, they allow citizen scientists to screen their drinking water and ambient water for relative levels of fecal bacteria more readily. If successful, the CBT may be turned into a kit and provided on a wider scale for next year’s monitoring event.
Macroinvertebrates are indicators of water quality.Approximately 90 citizen scientists collected macroinvertebrates from streams in three different areas of the island – Rio Piedras, Rio Mameyes, and a tributary of the Rio Grande de Arecibo. Aquatic macroinvertebrates are creatures that lack a vertebrate, an internal skeleton like mammals. Macroinvertebrates in streams and rivers include insects (caddisflies, beetles, dragonflies), crustaceans (shrimp, crayfish, crabs), mollusks (snails, mussels, clams), and worms. Volunteers were trained on invertebrate ecology, general habitat and water quality requirements, taxa identification, and use of macroinvertebrates as indicators of healthy and poor water quality. The volunteers used the SJBEP field protocol to collect macroinvertebrates and make a determination of the water quality at the stream site. Additional samples were collected with kick nets to compile a taxa list of macroinvertebrates observed. PREQB was present for the demonstrations and would like to incorporate benthic macroinvertebrate data as a way to determine stream health.
To learn more about citizen science projects in EPA Region 2, visit: https://www3.epa.gov/region02/citizenscience/.
