Print2CAD
Version 2016 7th Generation 14.54.0.0 - as of post 30 Mar 2016
Top CAD Converter! PDF and Images to DWG - Bidirectional
Wide Input - Print2CAD converts PDF and image files into a DWG or DXF file, which can then be imported into any CAD
system for editing. Print2CAD is an autonomous and CAD system-independent program. Print2CAD also converts DWG/DXF
into PDF, TIFF/JPEG into DWG, DWF into DWG/DXF and HPGL into DWG/DXF.
OCR of Text - Print2CAD not only uses conversion and vectorization methods, but also uses OCR (Optical Character
Recognition) to reconstruct the content of a PDF or raster file. The program can also recognize the PDF text that has been
deconstructed into polyline fields, and/or pixel pictures as full and editable CAD text.
Calibration - Print2CAD can precisely adjust, de-skew, and turn the converted drawing with the help of any number of
arbitrary calibration points. One can be certain that a 3 foot thick wall will remain 3 feet thick after the conversion and
will not be 2.9 feet thick. Likewise, a horizontal line will stay horizontal after the conversion.
Entity Recognition - Print2CAD converts files into DWG version 14, 2000 - 2016 or DXF version 12, 2000-2016. All
vectors, lines, circles, arcs, surfaces, splines, text, and pixel images are transferred into DWG or DXF. The pixel images
can be converted into vectors, embedded or stored in separate files. Special functions generate circles and arcs. PDF
layer structure is supported, or if not available, this can be created on the basis of color or line widths. PDF characters
are put together to create a new text. PDF properties such as line widths and line types are also converted into
CAD properties.
Colors Recognition - Print2CAD converts PDF colors into CAD index of colors or full RGB colors. Print2CAD also
supports TTF fonts. With multi-page PDF documents, one can specify which pages to convert.
Cicle, Arc Recognition - Print2CAD recognize circles and Arcs. Normal well-created PDF files contain lines, hatches,
circles, and arcs as PDF element paths or PDF element Bézier curves. Circles or arcs do not exist in PDF definition; they
are Bézier curves or polylines. A human has the capability and intelligence to recognize circles and arcs, however for
software to have this same type of recognition takes a lot more effort. Print2CAD provides advanced methods for circle
and arc recognition.
Raster To Vector - Print2CAD converts and vectorizes raster pictures from PDF, HPGL, DWF, TIFF, and JPEG files.
The input files can be done using a scanner or generated directly from CAD systems in different quality levels. With the
help of Raster to Vector Methods, Print2CAD can recognize all circles, arcs, and lines. With the help of OCR (Optical
Character Recognition), Print2CAD can recognize Texts. With the help of Pattern Recognition, Print2CAD can recognize
dash or dash dotted line types. With the help of coordinate calibration, Print2CAD can correct the accuracy of the
converted drawing.
Text Recognition - Print2CAD merges characters into strings and places these strings as texts in the DWG or DXF
drawing. In PDF or DWF files, text is usually defined as separate characters or groups of characters with their own
insertion points. With the help of special internal methods. If the PDF, HPGL, DWF or TIFF /JPEG file contains text
which are exploded into lines, polylines, hatches or raster pictures one can use internal OCR (Optical Character
Recognition) methods to convert these types of "text" into real and native text.
Line Type Recognition - Print2CAD recognizes the dashed or chain dotted line types, and will connect them to
form a proper CAD line and/or polyline with a line type. The lines may have any angle of inclination.
System Requirements:
System:
- 32bit: Windows 10, Windows 8, Windows 7 ( SP1), Windows Vista® (SP1),
- 64bit: Windows 10, Windows 8, Windows 7 ( SP1), Windows Vista® (SP1)
RAM:
- Windows 10: 8 GB RAM (for TIFF, JPEG or scanned PDF Vectorization)
- Windows 8: 8 GB RAM (for TIFF, JPEG or scanned PDF Vectorization)
- Windows 7: 4 GB RAM (for TIFF, JPEG or scanned PDF Vectorization)
- Windows Vista: 2 GB RAM (for TIFF, JPEG or scanned PDF Vectorization)
Print2CAD™ Software is a stand alone Windows (32 and 64 bit) program based on TrustedDWG that works
independently with all CAD systems (and with all AutoCAD® versions including AutoCAD® 2016).
HOMEPAGE - Video tutorials and manual etc
Spoiler hXXp://www.backtocad.com/engl/engl-pdf-dwg.html
DOWNLOAD LINKS
Print2CAD 2016 7th Generation 14.54.0.0 | 121.4 MB
Spoiler http://rapidgator.net/file/cba9996b5dff2a1c56f2b1d3e705864e/SAnet.me.Print2CAD2016.rar.html
http://nitroflare.com/view/702959E61AC82C4/SAnet.me.Print2CAD2016.rar
Possible issue on win10 x64
http://rg.to/file/545b0d03c10bd09fe1bb96c6e90ac66d
http://www.nitroflare.com/view/F33BC0D73F5E05C/Sanet.me_Print2CAD_2016.zip
http://ul.to/jp8o0dgk
http://nitroflare.com/view/FBB3269E1310084/Print2CAD2016.rar
Portable Print2CAD 2016 7th Generation 14.54.0.0 - Slight delay before booting up
Spoiler http://turbobit.net/if84r0q6fxq1.html
http://hitfile.net/yrQsqZK
http://depositfiles.com/files/v4i12mn8v
https://sanet.me/confirm/url/aHR0cCUzQSUyRiUyRnJ1c2ZvbGRlci5jb20lMkY0NDgzNTEwOA==/
http://nitroflare.com/view/97278F60D2E3CDC/allSaNetPt2CAD2016.7z.
http://rg.to/file/712d65e21ad2e47f2e68b0a88242eb5a/P2C2016sanet.7z.html
NO QUESTIONS TO ME, "I NO NOTHING" But Feedback always welcome and THANKS OF COURSE
CAD properties.
converted drawing.
System:
RAM:
DOWNLOAD LINKS
