New ArcGIS Pro Add-in for Performance Monitoring: PerfTools
Are you curious to know how long ArcGIS Pro takes to render a particular bookmark or*spatial extent, or play an animation? Or have you needed to monitor how long it takes to make a spatial selection from your underlying data?
A new add-in for ArcGIS Pro, PerfTools, can help users capture this pivotal performance information. With PerfTools, a comprehensive scripting capability allows you to edit, run, and log performance scenarios as you make underlying changes to your hardware, virtualization environments, spatial data, or other key user workflows.*You’ll soon be able to discover any performance ramifications, make adjustments, and re-run. To get you started, we’ve enclosed several sample scripts with the PerfTools download.
For power users and GIS developers,*the scripting language of PerfTools is extensible, allowing you to develop custom commands.*Samples and documentation*from PerfTools will guide you through the process of adding your custom code and timers.
PerfTools is a free add-in*that can run on ArcGIS Pro 1.2 and 1.3. In future blog posts, we will highlight how to use some of its crucial functionality.
Download PerfTools for ArcGIS Pro 1.2 and 1.3
Disclaimer: This add-in is not supported by Esri Support Services; any questions or feedback regarding PerfTools should be forwarded to*perfqatools@esri.com
Ian S. – Performance Engineer
