Mapbox Directions is now using the latest version of the Open Source Routing Machine (OSRM), the open-source library powering our Directions products.
Some of the improvements you will see:
- Our Directions API and Distance API now use turn penalties for car routing, favouring routes with less turns
- Our Directions API now returns the mode of travel for each step (e.g. showing cars on ferries or when a bike needs to be pushed)
- Our Map Matching API now provides better results for traces with low sample rates
- Raster data is now supported, bringing us one step closer to the previously-introduced elevation-aware routing
- The new trip plugin computes the shortest round-trip given a set of coordinates, which provides an approximate solution to the NP-Hard Traveling Salesperson Problem
