Map This Way Android mapping application
Map This Way is an Android application suitable for cartographic field work. It lets you use your GPS equipped Android device as a mapping tool. Through an easy to use interface you may map Locations, Routes, Point of Interest or Polygon areas.
It is probably the most useful application that I have ever developed it can be used in professional field work, in the collection of high quality map data also in biking, hiking, trekking, traveling etc. It helps you map new paths and new locations, keep notes from your travels with coordinates, date and time.
Export you mapping data in KML files so you can view them in any modern GIS or in applications like WMS Viewer on line.​
