Import Multiple Files to a Database
I saw a question that deserves a new and improved answer:
Q: "I've often got a lot of raw data files, do I have to bring them in one at a time or is there a way to import them all at once?"
It used to be that the best way to do this was to use a script.  In Oasis montaj 9.0 it is now easier to import a large number of survey files at once. If you have multiple ASCII files in the same file format, you can now import all of them at the same time into a Geosoft database.
This can save you lots of time and avoids the need to create batch import scripts.
1. Go to Database > Import... > Ascii...
2. Browse to select multiple files:
