HP Designjet T1120 HD-MFP - MULTIFUNCTION PLOTTERS
Ideal For :
Superior copying, scanning, and printing of a wide range of applications, including line drawings, maps, renders, images, and posters
Primary application : Line drawings; Renderings; Presentations; Maps; Orthophotos Secondary Applications: Office Graphics
Deliver the highest quality without loosing any image detail with this HP MFP. Copy, scan, and print CAD and graphics output on demand with a fast device that delivers superior scan and print quality
Specifications
Model size
44 in
Functions
All-in-one functions
Print; copy; scan
Print Speed
Mechanical print time, US D color line drawing, Draft mode, plain
35 sec/page
US D color line drawings/hr, Draft mode, plain
56 D prints per hour
Mechanical print time, US D b&w line drawing, Draft mode, plain
35 sec/page
Memory
Memory, standard
Printer: 384 MB; scanner: 1 GB
Hard disk
Printer: standard, 80 GB; scanner: standard, 40 GB
Printing
Print technology
HP Thermal Inkjet
Resolution technology
Color layering technology
Non-Printable Area (imperial cut-sheet)
0.2 x 0.67 x 0.2 x 0.2 in
Ink types
Dye-based (C, M, Y, G, PK); pigment-based (MK)
Ink cartridges
6 (cyan, gray, magenta, matte black, photo black, yellow)
Maximum roll length
300 ft
Line accuracy
+/- 0.1%
Maximum black optical density
2.15 maximum black optical density (6 L *min)
Connectivity, standard
Printer: 1 Gigabit Ethernet (1000Base-T) port; 1 Hi-Speed USB 2.0 certified port; 1 EIO Jetdirect accessory slot; scanner: 1 Fast Ethernet (100Base-T) port; 1 FireWire (IEEE-1394a compliant) port
Print languages, standard
Adobe PostScript 3; Adobe PDF 1.6; TIFF; JPEG; HP-GL/2; HP-RTL; CALS G4; HP PCL 3 GUI
Paper Handling
Document finishing
Printer: sheet feed; roll feed; automatic cutter; scanner: sheet feed
Media types
Printer: bond and coated paper (bond, coated, heavyweight coated, super heavyweight plus matte, colored), technical paper (natural tracing, translucent bond, vellum), film (clear, matte, polyester), photographic paper (satin, gloss, semi-gloss, matte, high-gloss), backlit, self-adhesive (two-view cling, indoor paper, polypropylene, vinyl); scanner: non-abrasive paper, vellum, mylar, sepia, blueprints, plastic film, plastic laminate, foam board, cardboard. (No plywood, stone plates, metal plates or abrasive, dirty, rough, sharp edged, metal clamped, or burned surfaces or transparencies)
Media sizes, standard
A; B; C; D; E
Rolls External Diameter
5.3 in
Media thickness (by paper path)
Up to 31.5 mil
Scanning
Linear scan speed
Color (200 dpi/400 dpi Turbo): up to 2 in/sec; black and white (200 dpi/400 dpi Turbo): up to 6 in/sec
Scan resolution color (best)
300 x 300 dpi
Scan resolution, optical
Up to 508 dpi
Scan resolution, hardware
Up to 508 x 508 dpi optical resolution
Scanner type
Sheetfed
Scan size, maximum (flatbed)
42-in wide
Copying
Copy reduce/enlarge settings
1 to 10000%
Maximum number of copies
Up to 1000 copies
Compatible operating systems
Windows Vista (R) (32 and 64-bit); Windows Server 2008 (32 and 64-bit); Windows XP Home and Professional (32 and 64-bit); Windows Server 2003 (32/64 bit); Mac OS X v 10.4; Mac OS X v
حمل البورشور:
http://www.akiradata.co.id/brosur/HP Designjet T1120 HD-MFP Edit.pdf
