HiBase Group Advanced DBF Converter v5.61
السلام عليكمبرنامج تحويل ملفات DBF HiBase Group Advanced DBF Converter v5.61صورة: http://u.damasgate.com/001/4/rhwzh2jlgw2o965355s3.jpg DBF Converter is a versatile yet easy-to-use conversion program. It has a familiar Wizard-like interface but can also be used as a command-line utility for batch file processing. DBF Converter supports all the modern data interchange formats, such as XML, CSV, TXT, HTML, RTF, PRG and others. You can even convert your DBF table into a SQL script. The program builds a sample data record allowing you to build filtering ruleshttp://s14.alxa.net/001/5/HiBase.Group.Advanced.DBF.Converter.v5.61.rarPassword:damas
