The GeoTree Lidar Tool Extension (GeoLiTE) is developed at the GeoTREE Center (University of Northern Iowa) in order to assist the processing and analysis of LiDAR data. The following are the main functions that GeoLiTE can provide:
DOWNLOAD :
http://www.geotree.uni.edu/media/GeoLITE.ziptutorial :
http://mm1.uni.edu:8080/1/mp3/geo_tree/lidar.rmofficial site :
http://www.geotree.uni.edu/en/extensions/geolite/Note : for ArcGIS 10
- Convert LAS file to XYZI file
- Merge and clip multi-tile LiDAR data to a user defined analysis extent.
- According to different resolution requirement, LAS or XYZ points can be sampled to keep necessary percentage of points.
- With accurate GPS point collection, DEM can be evaluated by calculating RMSE (Root Mean Square Error).
- Directly derive terrain and DEM from LiDAR data.
- Batch derive slope, contour, hillshade, and aspect from DEM
- Visualize lower elevation areas with the Water level tool. Useful for flood management.
- ArcGIS 9.3 and 10.0 are supported.
DOWNLOAD :
