شيماء جمال
مشرفة قسم المناقشات العامة
Below list of free viewer
1. Free TatukGIS Viewer
The TatukGIS Editor and free GIS Viewer are different editions of the same Windows desktop application. The Editor is a commercial product with the full set of features. The free Viewer product is a slimmed down version of the Editor.
DOWNLOAD :
Code: [Select]
http://www.tatukgis.com/Downloads/TrialFreeVersions/Viewer.aspx
REGISTER FIRST FOR FREE
2. ArcGIS Explorer and ArcExplorer
ArcGIS Explorer is a free GIS viewer that gives you an easy way to explore, visualize, and share GIS information. ArcGIS Explorer adds value to any GIS because it helps you deliver your authoritative data to a broad audience.
With ArcGIS Explorer, you can
* Access ready-to-use ArcGIS Online basemaps and layers.
* Fuse your local data with map services to create custom maps.
* Add photos, reports, videos, and other information to your maps.
* Perform spatial analysis (e.g., visibility, modeling, proximity search).
DOWNLOAD
Code: [Select]
http://gisupdates.esri.com/ArcGISExplorer/Build1500/ArcGISExplorerDownload.exe
ArcExplorer has been superseded by ArcGIS Explorer. but you can still download at this links :
ArcExplorer—Choose your platform
Code: [Select]
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.all
3. Geomedia Viewer
GeoMedia Viewer is an easy to use, FREE GIS software application for desktop viewing and distribution of geospatial data. It allows an organization to maximize the value of its geospatial data by extending availability to novice users who wouldn’t otherwise have access because of the barriers of purchasing and learning how to use a full GIS software application.
DOWNLOAD
MAJOR RELEASE
Code: [Select]
https://support.intergraph.com/DownloadFreeAccess.asp?id=3660
MINOR RELEASE
Code: [Select]
https://support.intergraph.com/DownloadFreeAccess.asp?id=4397
4. LizardTech GeoViewer 4.1
LizardTech GeoViewer is LizardTech's free, standalone application for viewing geospatial imagery, vector overlays, and LiDAR files. LizardTech GeoViewer enables you to combine, view and export visual layers from varied sources, such as local repositories, Express Server catalogs, and WMS and JPIP servers, and provides tools for visualizing LiDAR data in MrSID and LAS formats. LizardTech GeoViewer supports a wide range of input formats and exports to GeoTIFF, PNG and JPEG. Version 4.1 adds support for viewing MG4 files created using LiDAR Compressor 1.1. LizardTech GeoViewer is the most efficient means of viewing MrSID and JPEG 2000 images.
DOWNLOAD
32bit
Code: [Select]
http://bin.us.lizardtech.com/geoviewer/4.1/win32/setup.exe
64bit
Code: [Select]
http://bin.us.lizardtech.com/geoviewer/4.1/win64/setup.exe
5. Autodesk Design Review and DWG Trueview
Accelerate your design reviews with Autodesk® Design Review software. It’s the free*, all-digital way to view, mark up, print, and track changes to 2D and 3D designs—without the original design software.
Autodesk® DWG TrueView™ software is a free* stand-alone DWG™ viewer with DWG TrueConvert™ software included. Built on the same viewing engine as AutoCAD® software, DWG TrueView enables you to view the latest DWG and DXF™ files, just as you would in AutoCAD. By also installing the free* Autodesk® Design Review software, you can then open DWG files in Design Review to take advantage of powerful measure and markup capabilities, sheet set organization, and status tracking.
DOWNLOAD
Code: [Select]
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=12423405
NOTE :
1. Please check "Also install the DWG TrueView to open DWG files directly from within Design Review." Option
2. This is Online installer,
6. ERDAS VIEWFINDER and ERDAS ER VIEWER
ERDAS VIEWFINDER
A free viewer for quickly displaying a variety of geographic imagery (including 16-bit data), rapidly reprojecting different data types into the same projection system, displaying multiple images in a single viewer, and working in multiple open viewers, at the same time. ERDAS ViewFinder uses technology developed by ERDAS for Stereo Analyst and ERDAS IMAGINE, such as embedding multiple views in single windows and reprojecting imagery on the fly. ViewFinder offers a range of image manipulation capabilities, packaged into a clean, simply designed user interface. Users can continuously roam, pan, and zoom the display imagery, at any scale. Additionally, users can overlay, query, measure, smooth, sharpen, and enhance imagery. The software supports ERDAS IMG, TIFF, TIFF World, GeoTIFF, and MrSID image files, including 16-bit and floating point data types.
New features in version 2.1
* Military Grid Reference System (MGRS) coordinate display in the Inquire Cursor dialog.
* Brightness and Contrast thumbwheels have been added for quick and easy image enhancement.
* Copy the contents of the Main View to the Windows clipboard. Data is then easily available for pasting into any application which uses the clipboard.
* Image information can be displayed, such as the number of rows, columns and bands, layer statistics, projection parameters, etc. Provision is also made for building image statistics and pyramid layers.
* Extended library of US and international projection systems for reprojecting to and from.
* Extended range of raster formats are supported, including JPEG (JFIF), ERMapper .ers and generic binary BIL, BIP and BSQ formats.
* Filter files on all raster formats to see all supported images in a directory.
* Quickly swap between non-stretched and 2 Standard Deviation modes of displaying the images. If an image has been pre-processed to stretch its data across the entire data range, then you may not want to have displayed it with the “Automatically Stretch Contrast” display option on and wish to swap to no stretch without redisplaying the image.
* Easily display separate files as a multi-band True Color image. Some data providers deliver multispectral images as separate files (one band per file). You can now open one of these bands as a True Color image and then use the Band Combinations dialog to add in other bands to the color guns.
* Initial display speed has been vastly improved. In some instances images may display an order of magnitude faster than in previous versions of ViewFinder.
DOWNLOAD
Code: [Select]
http://www.erdas.com/tabid/84/currentid/2537/default.aspx
NOTE : REGISTER FIRST FOR FREE
ERDAS ER VIEWER
ERDAS ER Viewer is a free, easy-to-use image viewer featuring interactive roaming and zooming with very large JPEG 2000 and ECW files. It can also read most other common file types. Installing ERDAS ER Viewer also lets you embed large geospatial images in your Microsoft Word documents.
File formats supported
Fast image viewing for the following formats
• JPEG 2000
• ECW
• Universal Data Format (UDF) images
• ER Mapper images
• TIFF and GeoTIFF images
• SPOT View images
• ESRI BIL (ARC/INFO and ArcView) images
• Smart Data ER Mapper algorithms
• National Imagery Transmission Format (NITF)
• ERDAS Imagine (IMG)
• ArcInfo ASCII Grid (ASC)
• Portable Network Graphics (PNG)
• USGS SDTS (DEM)
Printing
ERDAS ER Viewer can print to common large-format printers.
DOWNLOAD :
Code: [Select]
http://www.erdas.com/Products/ERDAS.../84/currentid/2585/objectid/2585/default.aspx
REGISTER OR LOGIN FIRST FOR FREE
7. Cartomap viewer
Key Features
* Use with any database
* Supports for ArcView shape and MapInfo files
* Import DXF Entities
* Various spatial analysis functions
* Various thematic routines
* Automatic labelling
* Advanced line formating
DOWLOAD
CartoMAP Viewer 1.1
Code: [Select]
http://www.cartoworld.com/downloads/viewer/CMapViewer20_bde.zip
CartoMap Viewer 1.1
- Small Dbisam footprint edition.
Code: [Select]
http://www.cartoworld.com/downloads/viewer/CMapViewer20_dbisam.zip
DOWNLOAD :
Code: [Select]
DOWNLOAD
Code: [Select]
Code: [Select]
3. Geomedia Viewer
DOWNLOAD
MAJOR RELEASE
Code: [Select]
MINOR RELEASE
Code: [Select]
DOWNLOAD
32bit
Code: [Select]
64bit
Code: [Select]
DOWNLOAD
Code: [Select]
NOTE :
ERDAS VIEWFINDER
DOWNLOAD
Code: [Select]
ERDAS ER VIEWER
• JPEG 2000
• ECW
• ER Mapper images
• SPOT View images
• USGS SDTS (DEM)
Printing
DOWNLOAD :
Code: [Select]
7. Cartomap viewer
Key Features
DOWLOAD
CartoMAP Viewer 1.1
Code: [Select]
CartoMap Viewer 1.1
Code: [Select]
