This week I’d like to provide you an excerpt from my most recent book, Intro to ArcGIS API for JavaScript 4. The book is still being written, but if you purchase the book, you’ll get updates as they come along. I’m currently working on section that covers Popups that I will be releasing soon.
I’ve actually come down with a cold this week, and wasn’t up for doing a video, but I’ve been wanting to do an excerpt like this for a while, so I figured now is as good a time as any!
The following is an excerpt from Chapter 3 that covers Views and Layers available in the API. I had some issues with the markdown conversion for this blog, but the PDF version looks pretty good.
Layers
As mentioned earlier, not all layers are supported in the initial release of the 4 API.
But retrieving those layers is very easy to do.
To access the layers on the map, you can simply retrieve them from the map.layers property.
This property will provide you with the operational layers of the map, which means no basemaps.
If you want all the layers, including the basemap, you can use the map.allLayers property.
This is a much simpler API than in 3.x.
If you only care about the basemap, you can get that via the map.basemap property.
To reiterate, the Views and the LayerViews are what actually draw the data for the map.
They control the display of graphics, the extent, and any other visual properties.
The Map and Layers are containers of that data.
They are the models for your map, which means they can be treated like models in your application development.
The Map and the Layer can be used as a datasource for charts or tables or any other type of custom component that may not even have a map to display.
That’s a powerful feature of the API.
There are a handful of layers available in the API, that each serves a different purpose.
You can read more details about each type of layer in the API documentation, but these are some of the more common layers.
The GraphicsLayer is probably the simplest layer you can work with.
As the name suggests, it simply contains graphics that are displayed on the map.
const graphicsLayer = new GraphicsLayer({ graphics: [graphic1, graphic2, graphic3]});You can add graphics to the GraphicsLayer via a couple of methods.
// add a single graphicgraphicsLayer.add(graphic);// add an array of graphicsgraphicsLayer.addMany([graphic1, graphic2, graphic3]);Since you can’t set up a renderer or popup template for a GraphicsLayer, you’ll need to define the symbology and Popups on a per graphic basis.
// create a graphicconst graphic = Graphic({ attributes: { id: 1, city: "Los Angeles" }, geometry: new Point({x: xValue, y: yValue}), symbol: new SimpleMarkerSymbol({ style: 'circle', color: 'red', size: 10, outline: { color: 'rgba(255, 255, 255, 0.5)' width: 4 } }), popupTemplate: { title: "My Awesome Graphic!", content: "{*}" // display all fields }});// add it to graphicsLayergraphicsLayer.add(graphic);Popups will be covered in more detail in a later chapter.
If you need more robust support for your graphics, in particular using a renderer and popups, you’ll want to use a FeatureLayer.
The GraphicsLayer is ideal as simply a bag of miscellaneous graphics.
FeatureLayer
FeatureLayers are probably the most versatile and widely used layer type in the ArcGIS platform.
There are a few different ways you can initialize a FeatureLayer.
// Create via URLconst featureLayer = new FeatureLayer({ url: "http://services6.arcgis.com/m3L8QUZ93HeaQzKv/arcgis/rest/services/BeerAndBurgerJoints/FeatureServer/0"});// Create via a Portal itemconst featureLayer = new FeatureLayer({ portalItem: { id: "b126510e440744169943fd8ccc9b0c4e" }});By initializing a FeatureLayer via one of these two methods, the layer is now bound to a remote service.
The same way you can query the LayerView of a FeatureLayer, you can query directly against the FeatureLayer to find the features, ObjectIds or extent of a FeatureLayer.
You can also create a FeatureLayer via a FeatureCollection, although it has been simplified since the 3x version of the API.
const featureLayer = new FeatureLayer({ objectIdField: "item_id", geometryType: "point", // Define the fields of the graphics in the FeatureLayer fields: [{ name: "item_id", alias: "Item ID", type: "oid" }, { name: "description", alias: "Description", type: "string" }, { name: "title", alias: "Title", type: "string" }], // Define a renderer for the layer renderer: new SimpleRenderer({ type: "simple", symbol: new SimpleMarkerSymbol({ style: 'circle', color: 'red', size: 10, outline: { color: 'rgba(255, 255, 255, 0.5)' width: 4 } }) }), popupTemplate: { title: "{title}", content: "{description}" }, // This is a collection of Graphics source: [graphic1, graphic2, graphic3]});What we are doing here is defining the source for a FeatureLayer manually.
This is basically passing along a collection of graphics, defining the renderer for those graphics, as well as the fields and popup.
The benefit here is the ability to use a single renderer for multiple graphics as well as a single popup.
You will also have the ability to query against this FeatureLayer the same way you could query a FeatureLayer tied to a remote service.
Now, maybe you want to update the source features in a FeatureLayer.
You can do this in the following manner.
const graphicOfInterest = featureLayer.source.find(x => x.attributes.OBJECTID === oid);const target = graphicOfInterest.clone();const target.geometry = updatedGeometry;featureLayer.source.remove(graphicOfInterest);featureLayer.source.add(target);This lets you update individual graphics in the FeatureLayer source.
This comes in handy if you want to display updated GPS data or maybe change the symbology for individual features.
MapImageLayer
The MapImageLayer was previously known as the ArcGISDynamicMapServiceLayer.
It lets you load dynamic map services into your application, which unlike tiled image services, loads a single image for the entire map extent instead of many tiles.
It’s a fairly simple layer to work with. You can even define what sublayers are visible in the MapImageLayer, which used to be a cumbersome task.
Working with sublayers is now much easier.
const layer = new MapImageLayer({ url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer", sublayers: [{ id: 0, visible: true }, { id: 1, visible: true }, { id: 2, visible: true }, { id: 3, visible: false }]});You can simply define the visibility of each sublayer in the sublayers property of the MapImageLayer.
You could even take it a step further and provide a definitionExpression for individual subalyers.
const layer = new MapImageLayer({ url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer", sublayers: [{ id: 0, visible: true }, { id: 1, visible: true }, { id: 2, visible: true, // provide a definitionExpression definitionExpression: "pop2000 > 1000000" }, { id: 3, visible: false }]});This will now pass a definitionExpression for the sublayer to the dynamic map service when it requests the image.
This follows along with the theme of the entire version 4 of the ArcGIS API for JavaScript to provide a simpler API.
I fully expect people to implement the utility of the MapImageLayer in their applications with this easier to use API.
Starting at version 4.1 of the ArcGIS API 4 for JavaScript, the sublayers you define will be the only sublayers used in the MapImageLayer.
This is incredibly useful if you working with a Map Service that contains hundreds of layers, which I have personally seen far too many times.
You can also define a popupTemplate and even a renderer per sublayer.
const layer = new MapImageLayer({ url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", sublayers: [ { id: 3, visible: true, renderer: new SimpleRenderer({ symbol: new SimpleFillSymbol({ style: "solid", color: "dodgerblue", outline: { width: 0.5, color: "white" } }), label: "State boundaries" }), opacity: 0.5 }, { id: 2, visible: true, popupTemplate: { title: "{NAME}", content: [ { fieldInfos: [ { fieldName: "POP2000", visible: true, label: "Population for year 2000", format: { places: 0, digitSeparator: true } }, { fieldName: "POP2007", visible: true, label: "Population for year 2007", format: { places: 0, digitSeparator: true } } ] }, { type: "media", mediaInfos: [ { title: "Population", type: "column-chart", caption: "", value: { theme: "Grasshopper", fields: [ "POP2000", "POP2007" ], normalizeField: null, tooltipField: null } } ] } ] } }, { id: 0, visible: true, definitionExpression: "POP2000 > 100000" }]});This is incredibly powerful as you can now work with Map Services almost as easily as a FeatureService.
The ability to define a custom renderer for Dynamic Map Services has been available for quite some time in the 3.x version of the API and it’s been available as part of the ArcGIS Server Map Service for some time as well.
What is new, starting with the 4.1 version of the ArcGIS API for JavaScript is that it has simplified the API for developers to more easily take advantage of this feature.
The addition of being able to define popups per sublayer just adds to the utility of the MapImageLayer and I’m not afraid to say that I think this is now my personal favorite layer to work with as part of the API.
There is, even more, you can do with the MapImageLayer via query tables and table joins if you have that data available via your services.
Check out the documentation for those details and bask in the glory of the MapImageLayer.
As of right now, the book is approaching 100 pages once I finish the new Popup section. Go check it out and as usual keep an eye on this blog for more content!
The post Excerpt from Intro to ArcGIS API for JavaScript 4 appeared first on odoenet.
Layers
- GraphicsLayer
- FeatureLayer
- MapImageLayer
- SceneLayer
- VectorTileLayer
Note: If you are familiar with the GraphicsLayer from the 3.x version of the ArcGIS API for JavaScript, one main difference with the GraphicsLayer in version 4 is that it does not support a renderer. You would need to define the symbology per graphic instead of on the layer. This is because the GraphicsLayer can support graphics with different geometry types. This greatly simplifies creating basic graphics to display on the map.
Initializing a GraphicsLayer is fairly simple.const graphicsLayer = new GraphicsLayer({ graphics: [graphic1, graphic2, graphic3]});You can add graphics to the GraphicsLayer via a couple of methods.
FeatureLayer
MapImageLayer
