Distance Analysis Using ArcGIS "Web Course" - Esri VCT (Offline)
One important reason for performing GIS analysis is to determine proximity. Often, this type of analysis is done using vector data and possibly the Buffer or Near tools. In this course, you will learn how to calculate distance using raster datasets as inputs in order to assign cells a value based on distance to the nearest source (e.g., city, campground). You will also learn how to allocate cells to a particular source and to determine the compass direction from a cell in a raster to a source.
What if you don't want to just measure the straight line from one place to another? What if you need to determine the best route to a destination, taking speed limits, slope, terrain, and road conditions into consideration? In cases like this, you could use the cost distance tools in order to assign a cost (such as time) to each raster cell based on factors like slope and speed limit. From these calculations, you could create a least-cost path from one place to another. Because these tools account for variables that could affect travel, they can help you determine that the shortest path may not always be the best path.
If you want to take this course online and get certificate, you should pay 32$, for more information about the course follow this link.
http://training.esri.com/gateway/index.cfm?fa=catalog.webCourseDetail&courseid=2064Learning Objectives
After completing this course, you will be able to:
  • Create straight-line distance, direction, and allocation surfaces.
  • Determine when to use Euclidean and weighted distance tools.
  • Perform a least-cost path analysis.
DOWNLOAD
Demonstration + Exercises + Data
https://mega.nz/#!IgdB1QwAB.Regards
