As a child, nothing was more exciting to me than a chance to ride on an airplane. And after enjoying playing with the seatbelt buckle and feeling the crazy push of take-off acceleration, I would usually settle in and page to the back of the in-flight magazine where the airline route maps were: where were we going today, and where could we go tomorrow?
Destination Map
We can build route maps for any city in the world using airport and route data from OpenFlights.org. Start by uploading the airports.csv and routes.csv files
into CartoDB.
We can see every destination available starting from Vancouver, Canada (airport code “YVR”) by making some custom SQL to join the airports table to the routes table and restricting to just the “YVR” routes:
SELECT a2.cartodb_id, a2.the_geom_webmercator, a2.city, r.airlineFROM airports a1JOIN routes r ON r.airport_st = a1.code_iataJOIN airports a2 ON r.airport_end = a2.code_iataWHERE a1.code_iata = 'YVR' AND r.codeshare IS NULL
That’s the data we want, but without the flight lines it lacks a sense of movement.
Simple Route Map
Our query is already joining the airports twice: once for the origin and once for the destination airport, so we can turn the end points into a line very easily using the ST_MakeLine() function:
SELECT a2.cartodb_id, a2.city, r.airline, ST_Makeline(a2.the_geom_webmercator, a1.the_geom_webmercator) as the_geom_webmercatorFROM airports a1JOIN routes r ON r.airport_st = a1.code_iataJOIN airports a2 ON r.airport_end = a2.code_iataWHERE a1.code_iata = 'YVR' AND r.codeshare IS NULL
That looks much better! But there’s something wrong about this map – actually two things wrong.
First, the routes are all straight lines, and they should be great circle routes, that’s how the airplanes fly!
Second, some of the routes go the wrong way around the world: no airline would fly from Vancouver to Sydney via Africa!
Great Circle Route Map
If we convert our lines into great circle routes, we can maybe kill both of these birds with one stone, since the great circle routes will go the right direction.
SELECT a2.cartodb_id, a2.city AS city, r.airline, ST_Transform( ST_Segmentize( ST_Makeline( a2.the_geom, a1.the_geom )::geography, 100000 )::geometry, 3857 ) as the_geom_webmercatorFROM airports a1JOIN routes r ON r.airport_st = a1.code_iataJOIN airports a2 ON r.airport_end = a2.code_iataWHERE a1.code_iata = 'YVR' AND r.codeshare IS NULL
This is a bit complex, but reading the nested functions outwards starting from the ST_MakeLine(), we:
- Cast the point-to-point line to the “geography” type, which understands edges (also known as connections between nodes) as great circles; then
- Use the ST_Segmentize(geography) function to add points to the line along the great circle (so when we put it back on the flat map, it’ll appear curved); then
- Cast the line back into the “geometry” type we use for flat mapping; and finally
- Transform the coordinates of the line using ST_Transform(geometry, srid) to the web mercator projection we use on our flat maps.
But what is going on with those horizontal lines?
Great Circle Route Map with Dateline Fix
There’s a gap, right where the horizontal line appears.
Everything is fine until an edge on the great circle route tries to cross the dateline. Then it zings around the world in order to hook up to the next edge. Fundamentally our map still does not understand the circularity of the world, even though the edges we built do understand it. We have to work around the limitations of the flat map, by chopping our data at the dateline to avoid having edges that cross it.
<div class="highlight">-- First build our lines just as before, this can be any raw data you-- need to feed into a dateline chopping processWITH lines AS ( SELECT a2.cartodb_id, a2.city, r.airline, ST_Segmentize(ST_Makeline(a2.the_geom, a1.the_geom)::geography,100000)::geometry as the_geom FROM airports a1 JOIN routes r ON r.airport_st = a1.code_iata JOIN airports a2 ON r.airport_end = a2.code_iata WHERE a1.code_iata = 'YVR' AND r.codeshare IS NULL),-- Now break the input data into two sets, one to split and one to leave -- unprocessed. Objects that cross the dateline will appear to be very wide -- (as they zing across the world) so we'll only chop features that are very -- wide. This is just for efficiency.tosplit AS ( SELECT * FROM lines WHERE ST_XMax(the_geom) - ST_XMin(the_geom) > 180),-- Narrow objects we'll leave un-chopped.nosplit AS ( SELECT * FROM lines WHERE ST_XMax(the_geom) - ST_XMin(the_geom) <span class="o">
