Canon iPF 710 36in - CAD & GIS PLOTTERS
Features
Blistering speeds with A0 prints in 56 seconds
Seamless CAD integration supporting HPGL/2 & HP RTL
1,200dpi for sharper, thinner line and high black density for CAD plan printing
5-colour printing for superb graphics
INK & PRINTHEAD CANON IPF 710 Series
Class 36-inch
Ink Type Pigment and Dye reactive ink, 5 colors (MBK x 2, BK, C, M, Y)
Maximum Print Resolution 2,400 x 1,200 dpi
Printing Speed (A0 Roll)
Plain paper - 0:56 (Fast-CAD)
Coated Paper - 2:31 (Standard-CAD)
Photo Glossy Paper - 4:44 (Standard-Full Colour Image)
Dimensions, Weight Net:
Main Unit with Printer Stand and Basket 1,507 (W) x 871 (D) x 1,094 (H) mm ; Weight: approx. 64kg
Packaged:
Main unit, 1,695 (W) x 760 (D) x 722 (H) mm; Weight: approx. 79 kg
Stand and Basket 1,370 (W) x 691 (D) x 194 (H) mm; Weight: approx. 15 kg
Power Supply Input power - AC 100 - 240 V (50/60 Hz)
Power consumption - 140 W or less
Standby power consumption (At the low power mode)
100 V - 120 V – 5.0 W or less (when IEEE1394 is mounted, 10 W or less)
220 V - 240 V – 6.0 W or less (when IEEE1394 is mounted, 11 W or less)
Power off (standby) - 1 W or less (In compliance with Executive Order of the President of the United States of America)
Operational Environment Temperature: 15 - 30°C, Humidity: 10 - 80 % (Condensation free)
Acoustic Noise Acoustic pressure - Operation: 52 dB (A) or less, Standby: 35 dB (A) or less
Acoustic power - Operation: 6.6 Bels or less
Minimal Line Width 0.02mm (Theoretical value)
Line Accuracy +/- 0.1 % or less (User adjustments necessary. Printing environment media must match that used for the adjustments. CAD paper required: Plain paper, CAD tracing paper, coated paper, CAD translucent matte film only.)
Operation Panel Display Large LCD: 160 x 128 dots, Key x 12, LED x 5
Language on Operation Panel US-English, Japanese
Language on LCD US-English, French, German, Italian, Spanish, Russian, Chinese (simplified), Korean, Japanese (Kanji)
Printer Language GARO, HP-GL/2, HP RTL
Interface USB2.0 Hi-Speed
Type: Built-in
Mode: Full Speed (12 Mbit/sec), High Speed (480 Mbit/sec), Bulk transfer
Connector type: Series B (4 pins)
Ethernet Type: Built-in
Standard: IEEE 802.3 10base-T; IEEE 802.3u 100base-TX / Auto-Negotiation; IEEE 802.3 x Full Duplex
Protocol IPX/SPX (Netware 3.2(J), 4.1 (J), 4.11(J), 4.2(J), 5.0(J), 5.1(J) SNMP (Canon-MIB), HTTP, TCP/IP, AppleTalk
IEEE1394 (Option)
Type: Slot card type
Standard: IEEE1394 - 1995, P1394a, Half duplex,
Data/Strb differential serial
Data-transfer time: 100 / 200 / 400 Mbit/sec.
Connector type: In compliance with IEEE1394 - 1995, 6 pins, No power supply
Operating Systems supported: Windows 2000, XP, Server 2003, Vista / Macintosh OS 9, OS X
Regulations CE Mark, CB Certification, TUV (GS), Gost-R, UL, FCC class B
PRINT HEAD
Model PF-03
Type Bubble-jet on demand
Head Configuration 6 colours integrated type (6 chips per print head)
Nozzle Pitch 1,200 dpi x 2
Nozzle per chip MBK: 5,120 nozzles, Other Colours : 2,560 nozzles each
Droplet size 4 pl per color
INK TANK
Model Model: PFI-102 (130ml)
MEDIA HANDLING
Roll Paper One Roll, Back-loading, Front Output
Cut sheet Front-loading, Front Output (Manual feed using media locking lever)
Media Type Roll paper: Standard Paper, Matt Coated Paper, Extra Matt Coated Paper, Opaque Paper, High Resolution Graphic Paper, High Resolution Barrier Paper, Photo Paper High Gloss, Photo Paper Satin, Photo Paper Semi Matt, Photo Paper Pearl, Photo Realistic Paper, Heavy Weight Glossy Photo Paper, Heavy Weight Satin Photo Paper, Commercial Proofing Paper, Commercial RC Proofing, Glossy Proofing Paper, Semi glossy Proofing Paper.
Media size Roll paper (width) - ISO: A3, A2, A1, A0, JIS: B2, B1, ARCH: 24", 30", 36" Others: 10", 14", 16", 17"
Cut sheet - ISO: A4, A3, A3+, A2, A1, A0, B4, B3, B2, B1, DIN: C4, C3, C2, C1, C0, JIS: B4, B3, B2, B1, ANSI: 8.5 x 11", 8.5 x 14", 11 x 17", 13 x 19", 17 x 22", 22 x 34", 28 x 40", 34 x 44", ARCH: 9 x 12", 12 x 18", 18 x 24", 24 x 36", 26 x 38", 27 x 39", 30 x 42", 36 x 48", Photo: 20 x 24", 18 x 22", 14 x 17", 12 x 16", 10 x 12", 10 x 15", 8 x 10", 16 x 20" (US Photo size), Poster: 20 x 30", 30 x 40", 300 x 900 mm, Others: 13 x 22"
Media Thickness Roll paper & Cut sheet: 0.07 - 0.8 mm
Maximum outside diameter of Roll Paper 150.0 mm
Media Core Size Internal diameter of roll core: 2" / 3" (Option)
Media Width Roll paper: 254 – 914.4 mm
Cut sheet: 203.2 - 917 mm
Minimal Printable Paper Length 203.2 mm
Maximum Printable Paper Length Roll paper: 18 m (Varies according to the OS and application)
Cut sheet: 1.6 m
Margins (Top, Bottoms, Sides) Recommended area:
Roll paper: Top: 20 mm, Bottom: 5 mm, Side: 7 mm
Cut sheet: Top: 20 mm, Bottom: 23 mm, Side: 7 mm
Printable area:
Roll paper: Top: 3 mm, Bottom: 3 mm, Side: 3 mm
Roll paper (borderless print): Top: 0 mm, Bottom: 0 mm, Side: 0 mm
Cut sheet: Top: 3 mm, Bottom: 23 mm, Side: 3 mm
Media Width for Borderless Printing 515 mm (JIS B2), 728mm (JIS B1), 594 mm (ISO A1),
841 mm (ISO A0), 10", 14", 16", 24", 36"
OPTION
Roll Holder Set (2-inch and3-inch core spindle) – RH4-32
IEEE1394 Expansion Board EB-05
CONSUMABLES
Ink Tank PFI-102 (130 ml) ; MBK, BK, C, M, Y
Print Head PF-03
Cutter Blade CT-05
Maintenance Cartridge MC-07
*1 For the information of purchasable media, contact your local sales representative.
*2 Maximum printable length varies according to the OS and application.
البورشور:
http://www.akiradata.co.id/brosur/CANON IPF 605.pdf
شيماء جمال
مشرفة قسم المناقشات العامة
