ArcGIS Pro 2.x Quick Start Tutorials - Learn the basics
Tutorial summary:
Open the project in ArcGIS Pro
Use tools on the ribbon in ArcGIS Pro
Open and dock panes in ArcGIS Pro
Explore views in ArcGIS Pro
Work with contextual tabs in ArcGIS Pro
Switch to dark theme in ArcGIS Pro
Create a new project in ArcGIS Pro
Insert a map in ArcGIS Pro
Work with the map and its layers in ArcGIS Pro
Create a 3D scene in ArcGIS Pro
Explore the Catalog pane in ArcGIS Pro
Navigate a 2D map in ArcGIS Pro
Navigate a 3D scene in ArcGIS Pro
Link views in ArcGIS Pro
Add data from the ArcGIS Living Atlas of the World in ArcGIS Pro
Add data from a geodatabase in ArcGIS Pro
Add data from a folder in ArcGIS Pro
Visualize your data in 3D in ArcGIS Pro
Explore regions and their attributes in ArcGIS Pro
Design fields in ArcGIS Pro
Query the table in ArcGIS Pro
Summarize table values in ArcGIS Pro
Chart sheep distribution by region in ArcGIS Pro
Configure pop-ups in ArcGIS Pro
Share the project as a project template in ArcGIS Pro
View the project template in your portal in ArcGIS Pro
Create a project based on the template in ArcGIS Pro
Import a map package in ArcGIS Pro
Explore the maps in ArcGIS Pro
Explore the layout in ArcGIS Pro
Create a scene from the map in ArcGIS Pro
Add layers to the scene in ArcGIS Pro
Add another elevation surface to the scene in ArcGIS Pro
Change a layer's elevation source in ArcGIS Pro
Symbolize the urban area in ArcGIS Pro
Symbolize the bus stops in ArcGIS Pro
Symbolize the bus routes in ArcGIS Pro
Symbolize population in ArcGIS Pro
Label suburbs in ArcGIS Pro
Set a visibility range for label display in ArcGIS Pro
Label historic buildings in ArcGIS Pro
Change label placement settings in ArcGIS Pro
Label civil defense centers in ArcGIS Pro
Prepare the map for sharing in ArcGIS Pro
Share the map in ArcGIS Pro
Explore the web map in ArcGIS Pro
View the map in a mobile app (opti in ArcGIS Proonal)
Insert a layout in ArcGIS Pro
Insert a map frame in ArcGIS Pro
Insert map surrounds in ArcGIS Pro
Insert text in ArcGIS Pro
Insert dynamic text in ArcGIS Pro
Add an overview map and extent rectangle in ArcGIS Pro
Export the layout in ArcGIS Pro
GIS English ArcGIS Pro 2018
credit : esri
