To share your work as a printed map, poster, or PDF, you will need to make a layout. A layout is a composition of one or more maps along with supporting elements, such as a title, a legend, and descriptive text. Some layouts include more than one map. For example, a layout may have a main map and an overview map to show the main map in a larger geographic context.
Contents:
Open the project in ArcGIS Pro
Insert a layout in ArcGIS Pro
Insert a map frame in ArcGIS Pro
Insert map surrounds in ArcGIS Pro
Insert text in ArcGIS Pro
Insert dynamic text in ArcGIS Pro
Add an overview map and extent rectangle in ArcGIS Pro
Export the layout in ArcGIS Pro
[h=3]Learn the Basics of ArcGIS Pro:[/h]ArcGIS Pro 01: Introducing ArcGIS Pro
ArcGIS Pro 02: Create a project in ArcGIS Pro
ArcGIS Pro 03: Navigate maps and scenes in ArcGIS Pro
ArcGIS Pro 04: Add data to a project in ArcGIS Pro
ArcGIS Pro 05: Explore your data in ArcGIS Pro
ArcGIS Pro 06: Create a project template in ArcGIS Pro
ArcGIS Pro 07: Import an ArcMap document into ArcGIS Pro
ArcGIS Pro 08: Convert a map to a scene in ArcGIS Pro
ArcGIS Pro 09: Symbolize map layers in ArcGIS Pro
ArcGIS Pro 10: Label map in ArcGIS Pro
ArcGIS Pro 11: Share a web map in ArcGIS Pro
ArcGIS Pro 12: Make a layout in ArcGIS Pro
GIS English ArcGIS Pro 2018
credit : esri
Contents:
credit : esri
