ArcGIS Pro 08: Convert a map to a scene in ArcGIS Pro
3D is an integral part of ArcGIS Pro. Any 2D map can be converted to a 3D scene for data visualization, exploration, or analysis. In this tutorial, you'll convert a 2D map to a 3D scene and work with its 3D viewing properties.
Contents :
Open the project in ArcGIS Pro
Create a scene from the map in ArcGIS Pro
Add layers to the scene in ArcGIS Pro
Add another elevation surface to the scene in ArcGIS Pro
Change a layer's elevation source in ArcGIS Pro
[h=3]Learn the Basics of ArcGIS Pro:[/h]ArcGIS Pro 01: Introducing ArcGIS Pro
ArcGIS Pro 02: Create a project in ArcGIS Pro
ArcGIS Pro 03: Navigate maps and scenes in ArcGIS Pro
ArcGIS Pro 04: Add data to a project in ArcGIS Pro
ArcGIS Pro 05: Explore your data in ArcGIS Pro
ArcGIS Pro 06: Create a project template in ArcGIS Pro
ArcGIS Pro 07: Import an ArcMap document into ArcGIS Pro
ArcGIS Pro 09: Symbolize map layers in ArcGIS Pro
ArcGIS Pro 10: Label map in ArcGIS Pro
ArcGIS Pro 11: Share a web map in ArcGIS Pro
ArcGIS Pro 12: Make a layout in ArcGIS Pro
GIS English ArcGIS Pro 2018
credit : esri
