With ArcGIS Pro, you can create maps and scenes by adding data from your own computer, from a local network, or from a project or map package. You can also add data from your ArcGIS Online or ArcGIS Enterprise portal, or another portal such as the Living Atlas of the World. In this tutorial, you'll add data from Living Atlas, from your project geodatabase, and from a folder connection.
Contents:
Open the project in ArcGIS Pro
Add data from the ArcGIS Living Atlas of the World in ArcGIS Pro
Add data from a geodatabase in ArcGIS Pro
Add data from a folder in ArcGIS Pro
Visualize your data in 3D in ArcGIS Pro
[h=3]Learn the Basics of ArcGIS Pro:[/h]ArcGIS Pro 01: Introducing ArcGIS Pro
ArcGIS Pro 02: Create a project in ArcGIS Pro
ArcGIS Pro 03: Navigate maps and scenes in ArcGIS Pro
ArcGIS Pro 04: Add data to a project in ArcGIS Pro
ArcGIS Pro 05: Explore your data in ArcGIS Pro
ArcGIS Pro 06: Create a project template in ArcGIS Pro
ArcGIS Pro 07: Import an ArcMap document into ArcGIS Pro
ArcGIS Pro 08: Convert a map to a scene in ArcGIS Pro
ArcGIS Pro 09: Symbolize map layers in ArcGIS Pro
ArcGIS Pro 10: Label map in ArcGIS Pro
ArcGIS Pro 11: Share a web map in ArcGIS Pro
ArcGIS Pro 12: Make a layout in ArcGIS Pro
GIS English 2018
credit : esri
Contents:
GIS English 2018
credit : esri
