ArcGIS Pro 02: Create a project in ArcGIS Pro
ArcGIS Pro helps you organize and manage the resources related to a work project. To do this, it uses a project file (.aprx) as its basic file type. An ArcGIS Pro project may contain maps, scenes, layouts, data, tools, and other items. It may contain connections to folders, databases, and servers. Content can be added from online portals such as your ArcGIS organization or the ArcGIS Living Atlas of the World.
In this tutorial, you'll create a new, blank ArcGIS Pro project. You'll add a map to the project and convert the map to a 3D scene.​
Contents :
Create a new project in ArcGIS Pro
Insert a map in ArcGIS Pro
Work with the map and its layers in ArcGIS Pro
Create a 3D scene in ArcGIS Pro
Explore the Catalog pane in ArcGIS Pro
[h=3]Learn the Basics of ArcGIS Pro:[/h]ArcGIS Pro 01: Introducing ArcGIS Pro
ArcGIS Pro 03: Navigate maps and scenes in ArcGIS Pro
ArcGIS Pro 04: Add data to a project in ArcGIS Pro
ArcGIS Pro 05: Explore your data in ArcGIS Pro
ArcGIS Pro 06: Create a project template in ArcGIS Pro
ArcGIS Pro 07: Import an ArcMap document into ArcGIS Pro
ArcGIS Pro 08: Convert a map to a scene in ArcGIS Pro
ArcGIS Pro 09: Symbolize map layers in ArcGIS Pro
ArcGIS Pro 10: Label map in ArcGIS Pro
ArcGIS Pro 11: Share a web map in ArcGIS Pro
ArcGIS Pro 12: Make a layout in ArcGIS Pro
GIS English 2018
credit : esri
