ArcGIS for Javascript API - How to add WMS layer from geoserver
Hello I'm trying to add a WMS layer from a geoserver using the ArcGIS for Javascript API. I've gotten there example working from there sample codes but I'm unable to load my layer from the geoserver succesfully. When I load the web application I receive no errors so I don't even know what I might be doing wrong I just get the basemap and my search when the application is loaded the WMS layer just doesn't appear.
var map;require([ 'esri/map', 'esri/dijit/Search', 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', 'esri/geometry/Extent', 'dojo/_base/array', 'dojo/dom', 'dojo/dom-construct', 'dojo/parser', 'dijit/layout/BorderContainer', 'dijit/layout/ContentPane', 'dojo/domReady!'], function(Map, Search, WMSLayer, WMSLayerInfo, Extent, array, dom, domConst, parser) { parser.parse(); map = new Map('map', { basemap: 'streets', center: [-96, 37], zoom: 4 }); var jira_issues = new WMSLayerInfo({ name: 'postgis:jiraissues_reports', title: 'jiraissues_reports' }); var resourceInfo = { extent: new Extent(-126.40869140625, 31.025390625, -109.66552734375, 41.5283203125, { wkid: 4326 }), layerInfos: [jira_issues] }; var wmsLayer = new WMSLayer('http://opsengapp03.core.in.here.com:9999/geoserver/postgis/wms', { resourceInfo: resourceInfo, visibleLayers: ['jira_issues'] }); wmsLayer.spatialReferences[0] = 4326; map.addLayers([wmsLayer]); var s = new Search({ map: map }, "search"); s.startup();});
