AN ALL-PURPOSE SIMULATION SOFTWARE
AnyLogic simulation modeling software is an essential decision-making tool, which supports all existing modeling methods and therefore covers all your company’s simulation requirements. Industrial engineers, supply chain analysts, HR managers, market research analysts and strategic planners are using AnyLogic to leverage the power of dynamic simulation throughout the entire business lifecycle.
The flexibility and complexity of AnyLogic software allows the utilization of simulation and modeling in virtually all sectors and departments of your business, ensuring more profitable decision making and more efficient problem solving.from supply chain and logistics to market research and healthcare, AnyLogic can be applied to multiple levels of your business, including operation, tactical and strategic, quickly becoming an integral part of your organization. What could you achieve?
SEAMLESS INTEGRATION WITH OTHER SOFTWARE
AnyLogic is the leader in interoperability, meaning that you can use various GIS map sources (i.e.: OpenStreetMap, shapefiles), effortlessly upload or import CAD drawings and 3D models, or work with multiple optimization packages (i.e.: OptQuest), and distribution fitting tools (i.e.: Stat::Fit, ExpertFit). Plus, our software can be easily integrated with your current database (i.e.: Excel, MS SQL), and it can work with text or XML files, strengthening any and all of your projects.
Typical business management software (i.e.: ERP, BPM, BI) is proficient in completing simple predictive analysis based on approximation algorithms, but lack the capabilities of complete business optimization. Incorporating AnyLogic simulation models will serve as an additional level of business intelligence and can be seamlessly integrated with your CRM, ERP, BPM, and other software, supporting intelligent decision-making, on-the-fly optimization, “what-if” scenario testing, and more. From day-to-day operations, to long-term planning, AnyLogic will provide you with deeper and more global insight into your unique business.
WHAT'S NEW IN THIS VERSION?
- Read parameter values and configure models
- Create parameterized agent populations
- Generate entity arrivals in the process models
- Import data from other databases or Excel spreadsheets and store it in the readily available form
- Log flowchart activities, events, statechart transitions, message passing, and agent biographies.
- View resource utilization, waiting, processing and travel times
- Store and export statistics, datasets, and custom logs
AnyLogic 7.1. The new GIS capabilities. NEW GIS IMPLEMENTATION (TILED MAPS)
more about GIS Features
https://www.youtube.com/watch?v=z4gHwp6D8R4DOWNLOAD
32x bit
http://www.anylogic.com/files/anylogic-professional-7.2.0.exe64x bit
http://www.anylogic.com/files/anylogic-professional-7.2.0.x86_64.exeOLD VERSION 7.0.2 THE ONLY VERSION WITH MEDICINE ON THE INTERNET
32x bit
http://turbobit.net/ts46pr0ooien/AnyLgc.7.0.2.x86.WT.rar.html 64x bit
http://turbobit.net/l8tofw5047xi/AnyLgc7.0.2.x64.WT.rar.htmlPass for archive www.warezturkey.net
ـــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ
i tried to activate the new version 7.2 by the old crack of version 7.0.2 but unfortunately it did not work
some small changed in the new version 7.2, so we ask bigears or any other contributor to solve it and make a medicine for the new version
B.Regards
- No need to purchase and learn separate tools, AnyLogic enables a positive impact in every department of your business.
- Knowledge sharing across multiple departments using one simulation software instead of many.
- Link simulation models from various departments, for example, the inside of your distribution center to your external supply chain and your consumer behavior data, making precise inventory level or production plan recommendations.
- Built-in database
- Fluid Library
- Escalators and zigzag queues for pedestrian flow models
- Railway routing option for GIS models
- Shapefile conversion to AnyLogic markup
- The model now has access to all the data stored along with the online-based map (i.e. Open Street Map): cities, regions, road networks, objects (hospitals, schools, bus stops, etc.).
- You can place agents in specified points on the map, and make them move along existing roads or routes.
- You can create the required elements inside the model, using the built-in Google Maps-style search or new space markup elements (i.e. GIS Point, GIS Route, and GIS Region).
- Once downloaded, tiles are cached, enabling users to work in offline mode.
32x bit
32x bit
B.Regards
