Announcing: MapGuide Maestro 6.0M5
Here's a long overdue milestone of MapGuide Maestro 6.0
This fixes a long annoying issue where I forgot to include NetTopologySuite.dll in the installer, resulting in certain functionality being broken. Until now, you had to source this dll from the Maestro SDK.
Other changes include:
  • Now requires .net Framework 4.5
  • The Provider Template tool has been updated to use the Roslyn compiler to build the LocalNative provider
  • MgCooker: Don't start script generation or a tiling run if no actual maps or tilesets have been selected
  • The Local connection mode now uses mg-desktop 3.0
  • Fix: Feature Source XML does not properly update when switching editor to unmanaged file mode
  • Fix: Cannot make v3.0.0 untiled Map Definitions
Download
