These are the slides from my talk at the Algorithmic Governance workshop (for which there are lengthy notes in the previous post). The workshop explored the many ethical, legal and conceptual issues with the transition to Big Data and algorithm based decision-making.
My contribution to the discussion is based on previous thoughts on environmental information and public use of it. Inherently, I see the relationships between environmental decision-making, information, and information systems as something that need to be examined through the prism of the long history that linked them. This way we can make sense of the current trends. This three area are deeply linked throughout the history of the modern environmental movement since the 1960s (hence the Apollo 8 earth image at the beginning), *and the Christmas message from the team with the reference to Genesis (see below) helped in making the message stronger*.
This leads to environmental democracy principles (slide 11) and the assumptions behind them (slide 12). While information is open, it doesn’t mean that it’s useful or accessible to members of the public. This was true when raw air monitoring observations were released as open data in 1997 (before anyone knew the term), and although we have better tools (e.g. Google Earth) there are consistent challenges in making information meaningful – what do you do with Environment Agency DSM if you don’t know what it is or how to use a GIS? How do you interpret Global Forest Watch analysis about change in tree cover in your area if you are not used to interpreting remote sensing data (a big data analysis and algorithmic governance example)? I therefore return to the hierarchy of technical knowledge and ability to use information (in slide 20) that I covered in the ‘Neogeography and the delusion of democratisation‘ and look at how the opportunities and barriers changed over the years in slide 21.
The last slides show that despite of all the technical advancement, we can have situations such as the water contamination in Flint, Michigan which demonstrate that some of the problems from the 1960s that were supposed to be solved, well monitored, with clear regulations and processes came back because of negligence and lack of appropriate governance. This is not going to be solved with information systems, although citizen science have a role to play*to deal with the governmental failure. This whole sorry mess and the re-emergence of air quality as a Western world environmental problem is a topic for another discussion…
To demonstrate the way this triplet evolved, I’m using texts from official documents – Stockholm 1972 declaration, Rio 1992 Agenda 21, etc. They are fairly consistent in their belief in the power of information systems in solving environmental challenges. The core aspects of environmental technophilia are summarised in slide 10.This leads to environmental democracy principles (slide 11) and the assumptions behind them (slide 12). While information is open, it doesn’t mean that it’s useful or accessible to members of the public. This was true when raw air monitoring observations were released as open data in 1997 (before anyone knew the term), and although we have better tools (e.g. Google Earth) there are consistent challenges in making information meaningful – what do you do with Environment Agency DSM if you don’t know what it is or how to use a GIS? How do you interpret Global Forest Watch analysis about change in tree cover in your area if you are not used to interpreting remote sensing data (a big data analysis and algorithmic governance example)? I therefore return to the hierarchy of technical knowledge and ability to use information (in slide 20) that I covered in the ‘Neogeography and the delusion of democratisation‘ and look at how the opportunities and barriers changed over the years in slide 21.
