السلام عليكم3D Object Converter 6.506برنامج لاستيراد ملفات الثري دي وتحويلها الى صيغ اخرى + وظائف اخرى مثل الجداول والاحصائيات وعكس المشاهد والخرائط وحساب المساحات والاحجام وتحويل الجداول الى صور وغير ذلك الكثير لا استطيع ترجمته لكن اصحاب الاختصاص يمكنهم قراءة الملخص بالانجليزية عن عمل البرنامج أدناهصورة: https://u.damasgate.com/001/002/0l5hgtobc9zoen96shh6.jpg *3D Object Converter 6.x| 3.9 MB* 3D Object Converter a powerful 3D polygon model translation and interactive viewing shareware tool that allows arbitrary 3D model data to be imported from external sources, exported to various industry standard 3D file formats with great accuracy and quality. The program supports 651 file formats. *Features*Automated installation utility.Automatic file format recognition.Automatic polygon checking and repairing function during (scene) loading.Automatic self-checking function on every startup against virus infection.Batch converter module with Object statistics and Texture export function.Bone and Vertex Bone Weights support (not for all modules).Wireframe / Color wireframe / Real 3D wireframe / Flat shaded / Gouraud shaded / Vertex color shaded / Textured rendering mode.Command line conversion / view.Drag and Drop support (to load object).Fast import and export process.Fully dynamic memory allocation, so the program only uses as much memory as it needs.FullScreen OpenGL rendered interactive object viewer with mouse wheel support.Material per polygon support.Material editor.Multiplatform ASCII file loader technology.No DLL requisite.Options /for general, view, colors, import, export/ (CTRL-O).Online help.Portable application.Storing and processing the vertices as double precision.Storing and processing the faces as n-sided polygons. Functions / Tools Auto Rotate (CTRL-R).Calculate Areas and Volumes.Calculate Vertex Colors from Face Colors.Delete Scene UV Maps.Display the scene Area and Volume values on the toolbar (Tools/Options/View).Export the material table's textures to .bmp files.Flip Scene UV Map Vertically (CTRL-U).Geometry transformation.Internet WEB update (proxy support for v4.40 or above, but requires WEB update v1.10 or above).Invert Object Face Orientation (Object and Material Selector).Invert Scene Face Orientation (CTRL-I).Quick Material Information.Quick Object Information.Quick Polygon Statistics.Send OpenGL Bitmap To Clipboard (CTRL-C).Unwrap UV.UV Face Map to UV Vertex Map converter (Tools/Options/Import). *OS :* Windows95/98/Me/NT/2K/Server 2003/XP x32|x64/Vista x32|x64/Windows 7 x32|x64/Windows 8 x32|x64/Windows Server 2008 x32|x64 /Windows Server 2008R2 x64*Language *: Englishتحميل من سرفر البوابة4MBDownloadhttp://s13.alxa.net/1/3/3D.Object.Converter.6.506.rar
